31 Users Online (30 Members):
Forums >> Community >> Newbies >> footing queries
5 Posts No Rating |
hi all, i am working on revit structure 2009 and i am facing this strange problem while working with isolated foundations. as example : i have created a footing F1-1500x1500x500 and i have placed it at several places as required. now i need to create F2-1500x1650x500 for other columns. the moment i create and place F2 in the building, from the foundation schedule the type marks F1 & F2 vanishes and numbers of footings also vanishes. it considers F1 & F2 as same as the first dimension 1500 is common for both.this happens always when the width of two foundations are identical. am i going wrong somewhere ...please help me out thanks asit
Edit the family and duplicate it. giving it a new name. An instance property apllies to only that one, but a type property will apply to all of those unless you create a new one.
5 Posts No Rating |
thanks tim... i got my answer the next day..... actually problem was with sorting the footing by width in ascending order i.e. in the schedule of foundation when i changed the sorting order from 'by width' to 'by type mark' , the problem solved ...my mistake only... thanks again asit
footing queries |
Mon, Nov 17, 2008 at 1:08:42 AM
Continuous Wall Footing ? |
Thu, Aug 23, 2012 at 1:59:47 PM
13
Foundation Top of Footing (when Level is something other than 0'-0") |
Fri, Jan 29, 2016 at 1:40:13 PM
Top of Isolated Column Footing forced to snap to bottom of column |
Mon, Jan 13, 2014 at 7:41:43 PM
Wall profile footing issure |
Fri, Oct 3, 2014 at 7:06:49 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
