Forums >> Revit Building >> Technical Support >> step footing
36 Posts No Rating |
I am using revit2009, try to follow tutorial how create wall step footing, when come to the part selecting wall footings by hover over the footing and press tap key to select all of the footing, but my just don't work or don't do any of selection as shown in tutorial, any idea? I which I could make my file smaller, so I can attach with this, or anyone have any suggestion take out something to make file smaller.
![4 Stars: 202 Votes](/images/stars_4.gif) |
Hi, if i undestand, don't pick anything, go with your mouse to the wall you want (don't pick) then press the TAB key, Revit select the "Chain" of walls, now Yes, pick in the wall... i hope this is what you need...
I attached pdf file (from revit tutorial) showing wall with bearing footing in different elevation (1) following tutorail step 12 that I having trouble with, it not select all of the bearing ftg as shown in tutorial
Ohh, it's to define the "Work Plane", go with mouse (like in image) and click with TAB key, you gonna see the lines selection change every time you click in TAB, when all of those lines are Highlights pick with the left mouse button, then the work plane gonna be that rectangle, you can check if you select the right plane if you go to Menu and click in the second button (Blue grid)....
I still having problem with this tab key thing, in normal basic menu I can move mouse over the object and press tap key, the string of object will be selected. I can do this with all walls and other objects, but not with bearing footings. Just don't know why its won't. Now when come to modeling which come to the part where the work plane, I can not select string of object (with tab key) at all not even walls which have no problem in basic menu. I also attach the pdf file showing what I need to get to, a complete step footing
I think I found the way to do step ftg, I create a family from one of the isolate footing and edit the shape. Then load into project as isolate ftg. place next to bearing ftg. and it automaticly combine with other. I also attach the file, any suggestion or comment for improvement are welcome.
I attach the revised step footing.rvt. so now after all done it won't look like stair.
sorry, I did attach the wrong file, here step footing.rta
Here better and workable step ftg.rfa
Stepped Footing |
Sun, Nov 7, 2010 at 7:35:38 AM
newly created wall footing won't joint |
Mon, Nov 3, 2008 at 10:02:11 AM
Footing steps in plan |
Wed, Feb 3, 2016 at 2:10:50 PM
Step by Step Guides to Buildings |
Sun, Dec 7, 2014 at 7:57:47 AM
Rebar in Stepped Footing |
Mon, Dec 7, 2009 at 9:21:16 PM
Members: | 2081596 | Objects: | 23122 | Forum Posts: | 152273 | Job Listings: | 3 |
