75 Users Online (74 Members):
Forums >> General Discussion >> Revit Project Management >> Double ellipse mass
7 Posts No Rating |
Hi I tried to model a double ellipse mass, ellipse in plan and in elevation, but so ffar the only way I got to the shape I need is by subdivding the shape and then when trasnformig into a curtain wall, the the top gives me an irregular form that doesn't match the rest. Any suggestion how to do this and make the top join the rest of the shape? Thanks
Hi, I don't know how do you make that mass obj. some times when it's dificult to Revit I use Rhino, Revit don't "like" very much that kind of shapes (elipsoides), i can't see very well (in the image) the top of the model and the real problem, can you put an image more clear about your issue???
7 Posts No Rating |
ok, here is attached a bigger render of the area. You can see here how the to sections dont match when done from massing and courtin wall.
Glazing wall with ellipse form |
Tue, Feb 28, 2006 at 4:44:41 AM
problem with ellipse |
Fri, Apr 13, 2007 at 10:29:32 PM
Dimensioning an Ellipse? |
Thu, Apr 24, 2008 at 12:16:07 PM
extrude taper ellipse. |
Thu, Jul 23, 2009 at 10:54:45 PM
Double-Skin Facade as a "Curtain System" on a "Mass". |
Sat, Nov 21, 2015 at 7:10:28 AM
Members: | 2017148 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
