71 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> footing queries
Tue, Nov 4, 2008 at 12:59:52 AM | footing queries
asit
hi all,
i am working on revit structure 2009 and i am facing this strange problem while working with isolated foundations.
as example : i have created a footing F1-1500x1500x500 and i have placed it at several places as required. now i need to create F2-1500x1650x500 for other columns. the moment i create and place F2 in the building, from the foundation schedule the type marks F1 & F2 vanishes and numbers of footings also vanishes. it considers F1 & F2 as same as the first dimension 1500 is common for both.this happens always when the length of two foundations are identical.
am i going wrong somewhere ...please help me out
thanks
asit
Fri, Nov 14, 2008 at 11:26:50 AM | footing queries
justinblack
It sounds like you have duplicate type or instance marks.  Then when you place one the schedule doesn't know how to read it.  Either that or you have duplicate information in your schedule.
HTH
JB
Mon, Nov 17, 2008 at 1:08:43 AM | footing queries
asit
thanks
actually problem was with sorting the footing by width in ascending order i.e. in the schedule of foundation
when i changed the sorting order from 'by width' to 'by type mark' , the problem solved ...my mistake only... Winking
thanks again
asit
footing queries
Sun, Nov 9, 2008 at 12:51:01 AM
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:48 PM
13
Foundation Top of Footing (when Level is something other than 0'-0")
Fri, Jan 29, 2016 at 1:40:14 PM
Top of Isolated Column Footing forced to snap to bottom of column
Mon, Jan 13, 2014 at 7:41:44 PM
Wall profile footing issure
Fri, Oct 3, 2014 at 7:06:50 AM
Page generation time: 0.2205
