Forums >> Revit Building >> Technical Support >> Halftone setting in Visibilty Graphics
24 Posts No Rating |
Does anyone know how to overide the halftone setting in Visibility Graphics? I'm working in a Revit 2009 file that has CAD files linked. For our print, we're checking halftone in the link's visibility options, so that existing walls are displayed gray and new walls are displayed black. However, when we print, the halftone walls come out VERY light... almost non-existant (more like 1/4 tone). I'm wondering if there are project settings for this that I can edit? Help! Happy Halloween!
We too wish we could control "halftone" but you cannot. We worked with our printer to make it print better.
Thanks... I think I'm just going to mess with the printer setting, and if that doesn't work, go through and change each layer to a dark gray. Pain in the..., but it's got to be done!
3 Posts No Rating |
If you could adjust the halftone settings, then it couldn't be called HALFtone anymore could it? So sorry but the answer is no. You can adjust the settings of existing phases and instead of halftoning something, you can call it existing, depending on if it's a 3d element or not. I hope this helps some
You can also use the object styles, to correct the Color and width of the imported autocad lines....In the imported objects, imports in families, you should find the file layers...
Joao Cercas
On Revit 2010 (SP3) |
13 Posts No Rating |
In 2011 - Manage - Additional Settings - Halftone/Underlay - move the slider over from 50 to 75 or whatever works.
Visibilty Graphics Greyed Out |
Fri, Nov 22, 2013 at 10:42:50 AM
Design Options Halftone? |
Tue, Nov 20, 2018 at 10:58:56 PM
sweep visibilty |
Wed, Nov 18, 2009 at 12:51:27 PM
halftone hatch/fill pattern? |
Wed, Jan 16, 2008 at 10:14:12 AM
Wall Sweeps in Visibilty Graphics |
Wed, Jan 20, 2010 at 12:10:08 PM
Members: | 2104111 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
