42 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> elevation tag
Fri, May 13, 2005 at 5:23:24 AM | elevation tag
rolfwilliamwik
I have lost all my elevationtag's in a project, no mather what I do I can't seem to get them visible again. how can I get them to show without making new levels..
Thu, Jun 2, 2005 at 6:10:42 PM | RE: elevation tag
BIGMANJEE
if you are talking about elevations within plans, you most likely have the crop region on and cropped to close to the model. you need to be able to see the blue lines fo the elevations within the crop boundary. either that or your phasing is set so something weird. check the phasing in your view is set to none, rather than show all. hope this helps chief.
Beam Tag with Top of Steel Elevation ?
Fri, Aug 1, 2014 at 8:12:42 AM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
updating/changing elevation tag types
Wed, Mar 19, 2008 at 9:49:46 AM
Elevation tag
Thu, Nov 1, 2007 at 3:06:21 PM
if I happen to put two elevations on different sheets on the same elevation tag
Wed, Jan 12, 2011 at 3:00:58 PM
Page generation time: 0.7420
