33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Creating Custom Stairs From Scratch
Thu, Oct 30, 2008 at 9:20:04 AM | Creating Custom Stairs From Scratch
kdtran11
Hi All,
 I started using Revit about 4 months ago for a large project.  I want to make a set of custom stairs, with concrete  precase treads.  See attached images. They height of the stairs vary from floor to floor.  This is a ten story building with what should be two different floor heights.  I'm pretty sure that I will have to create a new system family for them.  How do I start?  Does anyone have any links to a "How To" instructions?  Or any suggestions?
Thanks so much for reading!
Thu, Oct 30, 2008 at 12:52:16 PM | Creating Custom Stairs From Scratch
System families are system ... you can not create them .... however
GOTO your on-line library area and load the project that has several types of stairs already defined.  Find one close to what you want and copy paste it into your project.
Thu, Oct 30, 2008 at 1:55:50 PM | Creating Custom Stairs From Scratch
LIZARD2806
3.5 Stars: 7 Votes
You can create your own stairs within the guidlines of the stair properties dialogue box.  It's a bit tedious and somewhat limited.  That being said, the stair you posted a photo of should be fairly simple to recreate.  Read through the help then start experimenting.
HTH
**Using Revit Architecture 2009, 2011, and 2012**
Creating Waal from scratch
Tue, Dec 20, 2005 at 12:35:29 PM
revit not drawing complete custom 3d stairs
Sat, Oct 3, 2015 at 4:17:55 PM
creating tables from scratch
Fri, Mar 27, 2009 at 11:41:07 AM
Error message creating stairs
Tue, Jul 13, 2010 at 7:27:12 PM
Custom stairs mess.
Thu, Oct 2, 2008 at 12:41:48 AM
Page generation time: 2.2361
