56 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> export two walls in two colors to Cad
![3.5 Stars: 11 Votes](/images/stars_3.5.gif) |
how do i export one wall in one color and an other wall in an other color to Autocad? i have two types of wall that both have a different solid fill color, but when i export to cad they get the same color,,,
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
![3 Stars: 10 Votes](/images/stars_3.gif) |
You can manipulate your Import/Export Settings under the File Menu. As far as I know you can only export two types, one A-wall (exterior) and I-wall (interior). It depends on how you labeled your wall properties (Interior or Exterior). You can export them separately, the first wall type (hide the other using select instances and hide elements). Then, do the same for the other type. You may want to export them to 2 separate files. Or you can open the first exported file, rename the layer and xref the second type into the same file.
Motto: "No Post left behind" |
Export to CAD - Colors |
Mon, Mar 3, 2014 at 7:37:38 AM
Revit Export to CAD |
Mon, Jul 21, 2014 at 8:35:51 AM
Export Linework colors to DWG |
Wed, Sep 14, 2016 at 12:04:12 AM
I canĀ“t export from revit to cad. |
Fri, Jan 18, 2013 at 9:10:32 AM
Layer Exports Colors |
Sun, Feb 1, 2009 at 1:49:31 PM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
