54 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009: Hidding the stairs over the cut plaqn
45 Posts No Rating |
Hi all. I want to know, is it possible to hide the lines (overhead lines) that display when I draw a stairs (in plan view)? I know I can use the linework tool (invisible lines) but I'd like to find a fastest way! Thanks all!
55 Posts No Rating |
Yes you can... go to VG, under Model Tab, and under visibility column, click the + sign in front of stairs, you will find stairs and stringers beyond cut line... un-tick those.. and then, click the + sign in front of railings, you will find railings beyond cut line... un-tick that... And you will get something like the attached image...
Stairs and plan regions (cut height) |
Mon, Apr 21, 2014 at 10:22:57 AM
Revit 2013 - Cut Wall under stairs. |
Thu, Oct 18, 2012 at 3:23:10 AM
Hidding |
Fri, Apr 1, 2011 at 2:40:15 PM
cut symbol on stairs |
Sun, Dec 4, 2011 at 8:21:55 AM
Plan Region & stairs |
Thu, Jun 18, 2009 at 1:28:36 PM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
