103 Users Online (102 Members):
Forums >> Revit Building >> Technical Support >> Pdf with no lineweights
I am using Revit 2008 and I'm wondering if there is a way to create a pdf of a view in Revit without any line weights? I'd like the pdf to read the way the image does in the model when I have all line weights turned off. Essentially, I want the option to create simple thin line drawing. I've tried going in and editing the object styles of model objects, etc. and even though everything is set to a line weight of 1, I still can't seem to generate a pdf with super thin lines. Help. Thanks.
Just create a view that does what you want.... ie - copy a floor plan & in VG, select all categories & over-ride the projection & cut lines to 1. ... ditto for
go to settings==> lineweights and set all 16 of the lineweights for the view scale you are trying to plot to the same lineweight. you won't be able to plot with any lineweights for that view scale until you re-set them, but it should work. HTH
I've actually already tried going in and setting all the lineweights to 1 and it did not change anything when I created a pdf. Do you think it has something to do with this kind of file format?
Check the size that you are printing the PDFs. If these are reduced scale then the lines won't be as sharp as they are on the screen. If they are full scale you should be able to get the thin lines that you want. Also try and print to a different printer. Some are able to print finer lines than others.
"I've actually already tried going in and setting all the lineweights to 1 and it did not change anything when I created a pdf. Do you think it has something to do with this kind of file format?" that's not what i'm talking about. you won't be setting setting any lineweights to 1. your are going to set all 16 lineweights to the same actual size based on the View scale you are using. based on that, it won't know how to print in any other lineweight but the single lineweight assigned to that view scale.
Plotting PDF's |
Tue, Jul 21, 2009 at 4:18:05 PM
Revit Lineweights not printing correctly |
Fri, Jun 14, 2013 at 1:27:49 PM
Lineweights Issue |
Thu, Nov 17, 2005 at 6:05:35 PM
Physical Print Quality of PDF's Produced from Revit |
Tue, Apr 23, 2013 at 9:49:54 AM
Lineweights Question |
Wed, Aug 3, 2005 at 4:03:11 PM
Members: | 2030725 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
