44 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Tips & Tricks >> Section cut disappears when I change the view range in plan view.
Tue, Oct 28, 2008 at 10:23:47 AM | Section cut disappears when I change the view range in plan view.
jetfavre
When I adjust the view range in a plan view the section cuts disappear. what am I doing wrong
Tue, Oct 28, 2008 at 3:45:24 PM | Section cut disappears when I change the view range in plan view.
JRMello
What do you mean by "section cuts?" Do you mean the section symbol in the plan?
Tue, Oct 28, 2008 at 3:50:07 PM | Section cut disappears when I change the view range in plan view.
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Sections have a vertical range as well as a lateral range. Go to a perpendicular view and adjust the top/bottom of the vertical range to within your new view range and the symbols will show on the adjusted plans.
Section line disappears from plan when section view is placed on same sheet
Thu, Sep 4, 2014 at 7:46:20 AM
REVIT 2010 - Section Cut Detail Mark & View Range
Tue, May 4, 2010 at 11:29:34 AM
Revit Architecture 2012 - Section shows view from behind cut line
Thu, Jan 10, 2013 at 12:38:20 PM
Plan view view range
Fri, Nov 2, 2018 at 6:59:27 PM
Model-In-Place Component adhering to plan's view range.
Mon, Apr 12, 2010 at 12:18:43 PM
Page generation time: 1.6592
