101 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Creating Callout of Linked CAD file
Tue, Oct 28, 2008 at 10:05:59 AM | Creating Callout of Linked CAD file
amber01aggie
We're experiencing vanishing issues in Revit Architecture 2009.
We have a linked CAD file as the overall background plan of a building and are wanting to use callouts to create Enlarged Plans of individual areas.  When we do so, the link doesn't appear in the callout view.  We've checked visibility settings to make sure the background is set to visible.  I'm new to links management, so this may be a simple issue, but it's causing us some production problems!
We'd appreciate the help if anybody has any ideas! Smile
Tue, Oct 28, 2008 at 10:10:52 AM | Creating Callout of Linked CAD file
tim123
4 Stars: 19 Votes
The CAD file needs to be inmported with the'Current View Only' box unchecked.  The part of the CAD plan should then appear in the callout.
Tue, Oct 28, 2008 at 11:33:27 AM | Creating Callout of Linked CAD file
amber01aggie
I did that (cool, it worked), but now only text is visible in the call out (no CAD link walls/doors/etc.)... checked visibility graphics and everything still seams to be on.  What am I missing?
 Thanks!
Tue, Oct 28, 2008 at 1:05:58 PM | Creating Callout of Linked CAD file
tim123
4 Stars: 19 Votes
Does the CAD drawing contain xrefs?  If these are overlaid and not attached then they wont come through to your Revit project.  Also check that any xrefs that may have been bound in are not blocks as this often causes display problems.  Explode the block if this is the case.
Tue, Oct 28, 2008 at 1:46:12 PM | Creating Callout of Linked CAD file
amber01aggie
No xrefs in orginal CAD file.  Only 2d lines.  No blocks either.  Hmmmmm....
Tue, Oct 28, 2008 at 2:34:47 PM | Creating Callout of Linked CAD file
amber01aggie
Fixed!!!  Thanks for your help TIM123!
I just had to make sure my callouts were PLAN callouts.  I knew it was going to be something silly like that!
Linked Cad File does not show Cad Xref's
Fri, Sep 10, 2010 at 10:13:50 AM
Constraining to linked CAD file
Thu, Apr 4, 2013 at 3:09:14 AM
Problem exporting view with linked CAD file
Wed, Mar 18, 2009 at 3:46:34 PM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:56 AM
unable to view linked CAD file with pipe
Thu, Apr 18, 2013 at 1:36:27 PM
Page generation time: 1.0616
