66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Atypic walls
7 Posts No Rating |
HAllo,
please, I am doing a historic building, which has walls with non rectangular base, a mean the width of the wall is not same. Can I convert a mass to a wall or can I extrude line skech to a wall (but not that the poly is a wall base line. I hope I have explained what I need. Please help
Thanx
If the faces of the wall aren't all vertical
You create an-inplace family for walls of varying thickness. Refer Mr GG tutorial on sculpted walls.
If the faces are vertical and there are just steps in the wall of different materials.
Use the stacked wall feature and stack the differing wall types, refer revit help on stacked walls.
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:42 PM
Walls |
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls. |
Sun, Dec 14, 2014 at 4:58:35 PM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
