36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stacked Wall Core
Mon, Oct 27, 2008 at 5:01:32 PM | Stacked Wall Core
maranelloboy
3 Stars: 2 Votes
I built a roof with a 1'-3" overhang from the core of the walls using the pick walls tool.  Many of the walls are stacked walls, and although each basic wall is set up with the proper core, my overhangs are measuring from the outmost surface.  Have any of you experienced this, and is there a solution?
Thu, Jan 7, 2010 at 12:55:26 PM | Stacked Wall Core
StephaJ
I am currently experiencing this same problem.  Did you ever figure out a way to make "choose wall, extend into wall (to core)" work?  I am sure each inividual wall core within the stacked wall is properly defined but within the stacked wall itself, it seems to be choosing an arbitrary core not relative to either of the walls.  My workaround right now is to lock lines to my wall core.  Let me know if you've discovered a better solution.
 Thanks!
Stacked Walls - how to set wall core
Mon, Apr 20, 2015 at 7:33:52 AM
Dimension Stacked Walls
Thu, Aug 18, 2011 at 12:23:35 PM
Stacked wall core boundary
Fri, Jul 20, 2012 at 6:56:41 AM
stacked wall line visable on the wrong side?
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Page generation time: 0.9014
