102 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Wall material is all grey in rendering
Sun, Oct 26, 2008 at 8:16:38 AM | Wall material is all grey in rendering
Akasha
I want to have a wall with white wood siding panels on the exterior of a house, but when I use Thermal_Moisture.Roofing_Siding Panels.Wood.Vertical.White.jpg as material, it is just grey when I render, and not seems like a siding panel. Sometimes when I render it also comes up with a error messages about the bump file, witch is by the way the same file I think, this error message doesn't allways appear. In the render material preview, the wall looks like it is supposed to. Anyone know what is wrong? I am new to Revit.
Sun, Oct 26, 2008 at 9:33:31 AM | Wall material is all grey in rendering
4 Stars: 202 Votes
Hi, see the image attached, your wall has several components, exterior to interior (like you can see in the image) didi you pick in the extrior finish and select the material you want? can you post some images (like i post) to see what's wrong???
Sun, Oct 26, 2008 at 5:51:44 PM | Wall material is all grey in rendering
Akasha
Yes I did...
Mon, Oct 27, 2008 at 6:13:04 AM | Wall material is all grey in rendering
4 Stars: 202 Votes
Can you put some images in 3d of your wall in the model and a render view to check???
Mon, Oct 27, 2008 at 1:15:53 PM | Wall material is all grey in rendering
Akasha
This is a rendered image from one corner of the house.
Mon, Oct 27, 2008 at 2:14:25 PM | Wall material is all grey in rendering
4 Stars: 202 Votes
In your material, like you can see in your image from textures, you have the "Sample Size" in the Render appearance to control the space those vertical lines (panels), you also has the "Brightness" to change the bright of the color...
Tue, Oct 28, 2008 at 11:48:17 AM | Wall material is all grey in rendering
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I would just keep playing with the color because I know when I'm trying to get a certain color with the materials when rendering they sometimes come out way different when they are rendered because of the lighting.
Edited on: Tue, Oct 28, 2008 at 11:48:32 AM
Edited on: Tue, Oct 28, 2008 at 11:54:23 AM
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Wed, Oct 29, 2008 at 4:49:44 PM | Wall material is all grey in rendering
Akasha
Yes this i correct. I thought they would be the look I wanted right away, but when I changed the exposure and the imagesize it became better. Thank you for the tips! :D
2008 Revit_ White walls rendering grey
Thu, Jul 10, 2008 at 11:50:26 AM
any trick in Revit rendering not make it so grey? [ 1 2 ]
Wed, Jan 5, 2011 at 3:09:07 PM
22
Color and surface in rendering remain grey
Thu, Jul 5, 2007 at 4:30:06 PM
White walls are dark grey when rendered?
Wed, Aug 10, 2005 at 10:57:55 PM
Rendering Help..! showing up grey
Fri, May 8, 2015 at 1:02:29 PM
Page generation time: 1.1020
