Forums >> Revit Building >> Technical Support >> Revit Arch 2009 (Student Version) cut/intersecting/deleting roof wall
12 Posts No Rating |
HELP HELP HELP – having so much trouble with Revit. I am trying to intersect the roof with a wall and delete the overlapping roof (See rcap.jpg). Also I am trying to cut an opening in the wall where the roof and exterior walls intersect the wall (see the sketchup screen shot scap.jpg). Please see attached files they will give more information. Ultimately you can see what I want to do in scap.jpg. I have included the revit file along with two screen shots of what I want to do here: ***LINKS REMOVED*** I'm new to forums and am a masters student and don't have time to read a million rules on posting. I'm sorry if I have broken any rules - Thank you so much for any reply and help. Susan
Edited on: Sat, Oct 25, 2008 at 9:03:24 PM
Hi and Welcome to Revit World, i create a video for you but i have problems with my JING video program, i don't know what a hell it's going on but check the model and see if this is what you want...
Edited on: Sat, Oct 25, 2008 at 2:17:02 PM
I dont see where the video or file post is - did you attach in the post? Where is the location?
I have some problems here but now i think it's ok, can you wait a few minutes? it's uploading the video...
Hi have some problems here and the file was more then 2MB, i was "purge" the file. Sorry for the delay, i have problems with the JING...
Edited on: Sat, Oct 25, 2008 at 2:25:41 PM
PERFECT!!!!!! Thank you so much. This is exactly what I was trying to do. I would really like to know how you did it. I'm sure you're busy - but if you can post the video or explanation sometime, I'd really appreciate it.
Again THANK YOU SOOOOOOO much.
I have the video it takes about 2 minutes to do it but i have some problems to upload the video, i think there is in the "Screencast.com" where i have my files, i try to solve the problem and when i do it i post here the video, its a promise, go to Plan Roof, pick in the roof and edit, you will see the line magenta on the right i move it to the wall and uncheck "Define slope" then go to the section 2 and pick in the wall where you want to make the opening, pick in top "Edit" and create in the place and the shape you want for the opening, finish and it's done...
Edited on: Sat, Oct 25, 2008 at 3:30:37 PM
No need for the video, your explanation was enough; I was able to do it.Again, thank you, thank you, thank you.
Hi again, a promise is a promise and i always keep my promises, this is the video: http://screencast.com/t/n6geRrVk
re-downloading Revit student version |
Fri, Feb 19, 2010 at 12:23:08 PM
Cut Fascia by roof |
Mon, Jun 25, 2012 at 10:39:49 AM
File in Student Version transfers to Professional Version |
Mon, Jul 26, 2010 at 12:06:11 PM
Revit Sheet Sets-Student Version |
Fri, Apr 22, 2016 at 5:45:59 PM
revit student version |
Mon, Oct 5, 2009 at 3:23:39 PM
Members: | 2022542 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
