Forums >> Revit Building >> Technical Support >> Creating lightning fixtures without a ceiling...
22 Posts No Rating |
Hi! I'm new to revit, and I know that this subject has been delt with in this forum lot's of times, but after reading through as many threads as I could find on the subject, I'm still stuck... I figured out, that to fight lightning without a ceiling, I need to make a new family and host it elsewhere... but how do I create a new familiy and then load the lightning component that I want to use in to it ? Or should I duplicate the component and then host it elsewhere (and how do I rehost it then) ?? Thx /jw
Hi, sorry for the delay, i gonna put a video to explain, it's uploading, wait a few minutes.. sorry but i have some problems with JING video program, i'm trying to solve that... see the video:http://screencast.com/t/IidswIRS the problem after all isn't in JING program, but my internet service...
Edited on: Sun, Oct 26, 2008 at 2:59:44 AM
Hi. Thx for the response, really great video. Is it possible to load a lamp that has already been drawn ? Fx. the lamp I've attached, it's ceiling based, but I can't figure out how to change it, so that I can attach it wherever I want. Is it only possible to do if you create and draw up a whole new family ? thx's for the help so far ! /jw
Hi again, YES it's possible, see the videos: 1º video: http://screencast.com/t/KIpJDyJkAE this is the 2º video: http://screencast.com/t/gqghFocb5n This is the 3º video: http://screencast.com/t/gmlpqID4v I hope this help you to clarify the problem... give me a feedback ok?
I'm really not getting this whole ceiling thing ...
Anybody know of a tutorial that explain in detail the need-to-know-stuff about ceilings in revit ?
I've tried to create a normal ceiling, but no matter which ceiling view I choose, I get the same message:
"None of the created elements are visible in Reflected Ceiling Plan: (01) Stue terræn View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
Thx's
/jw
Hi Typhoon! Thanks alot for the videos, they helped me out bigtime! Can I rotate the lightning fixture after I finished working with it ? ex. if I have a 35 degree roof that I want to set the fixture on, and get the idea of it hanging from the roof ? Also, is it possible to adjust the 'length' of the fixture as i place it, or do I have to create new families for every length ? Thank's again for all your help! /jw
Hi, in your family, you can create ref. planes with dimensions (angles and so one) to control the lenght, inclination... the lighting fixture i imported to a "Family Face based", so if you place in a roof that family keep with the inclination of the roof, if you want to rotate you must do it in the family not in the project, unless like i told you, if you create parameters to control that in project, like you saw in the videos you can rotate (in project) the "spot light" in any direction...
1 Posts No Rating |
" Hi again, YES it's possible, see the videos: 1º video: http://screencast.com/t/KIpJDyJkAE this is the 2º video: http://screencast.com/t/gqghFocb5n This is the 3º video: http://screencast.com/t/gmlpqID4v I hope this help you to clarify the problem... give me a feedback ok? " These links don't seem to work anymore. I'd be forever grateful if anyone can tell me where I can view these videos!
Sorry, but those videos are "GONE", it was made in October of the last year and I only have a few GB free in Screencast.com, so, sometimes I must delete the olders for create new ones... I think I gonna put them (news) in Megaupload then you can download and save in your hard-drive...
"I think I gonna put them (news) in Megaupload then you can download and save in your hard-drive...". Sorry Typhoon, you meant new ones (videos)??, good idea.....
Light Fixtures Not Placing/Cutting Custom Ceiling Family |
Tue, Apr 14, 2015 at 7:06:55 AM
Lighting Fixtures - being placed perpendicular to ceiling plane |
Tue, Apr 10, 2012 at 6:48:21 PM
Why are my light fixtures on wrong side of the ceiling? |
Fri, Dec 13, 2013 at 9:38:09 AM
Splitting a ceiling |
Fri, Nov 11, 2011 at 12:34:50 PM
ceiling grids through lighting fixtures |
Wed, Jan 18, 2017 at 2:32:52 PM
14
Members: | 2104701 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
