40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Superscript/subscript/degree text symbols in Revit
Mon, May 9, 2005 at 5:26:16 PM | Superscript/subscript/degree text symbols in Revit
sekta
Does anyone know if this is possible? I have recently moved to Revit from ACAD and am finding the text capabilities in Revit a bit frustrating! Cheers!
Mon, May 9, 2005 at 6:08:59 PM | RE: Superscript/subscript/degree text symbols in Revit
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the character map shortcuts: Hold "Alt" and type "0186" is your degrees symbol º Alt 0179 ³ cubed Alt 0178 ² Squared Alt 0216 Ø Diameter. HTH.
Mon, May 9, 2005 at 6:15:43 PM | RE: Superscript/subscript/degree text symbols in Revit
sekta
Excellent! Thanks very much!
Fri, Sep 26, 2014 at 3:07:42 AM | Superscript/subscript/degree text symbols in Revit
aehryl
To make text appear slightly above (superscript) or below (subscript) your regular text, use these keyboard shortcuts:
  • For superscript, select the text or number that you want, and then press Ctrl, Shift, and the Plus sign (+) at the same time.
  • For subscript, select the text or number that you want, and then press Ctrl and the Equal sign (=) at the same time.
Fri, Sep 26, 2014 at 7:13:17 AM | Superscript/subscript/degree text symbols in Revit
3.5 Stars: 395 Votes
aehrl....
You realize functionallity was different in 2005?
Did you test out your process.   It doesn't work in 2014.  It looks correct until you finish the text.  Then it reverts to normal text.
Edited on: Fri, Sep 26, 2014 at 8:07:28 AM
This user is online
Wed, Jul 5, 2017 at 9:10:49 AM | Superscript/subscript/degree text symbols in Revit
NkosiEcosse
Still broken in 2016
Text Symbols? [ 1 2 ]
Tue, Apr 28, 2009 at 2:43:34 PM
22
Symbols
Fri, Nov 25, 2005 at 5:29:24 PM
Text symbols [ 1 2 ]
Tue, Mar 10, 2015 at 10:14:14 PM
18
Symbols in Revit
Mon, Feb 6, 2012 at 7:05:09 PM
how to type degree symbol in text
Mon, May 21, 2007 at 11:54:29 AM
Page generation time: 2.3889
