53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Mass not showing completely
Fri, Oct 24, 2008 at 11:15:21 AM | Mass not showing completely
Suzque
I've added a mass to resemble a mansard roof and in 3D view the entire mass shows.  When looking at elevation views only a portion of the mass shows.  Any ideas?  Thanks!
Fri, Oct 24, 2008 at 3:43:11 PM | Mass not showing completely
4 Stars: 203 Votes
Hi there, can you put some images (screenshots) to figure out what are the problem???
Mon, Oct 27, 2008 at 7:51:52 AM | Mass not showing completely
Suzque
When exporting out my 3D image or an elevation into a jpg file it won't show the mass which defeats the purpose - any ideas?
Mon, Oct 27, 2008 at 9:32:26 AM | Mass not showing completely
4 Stars: 203 Votes
In the TOP of the screen, on the left of the icon "House (3d view)" you have a "3d rectangle in blue" pick on that button, the mass show up in the view or/and go to VG and check ON in the "Mass"...
Mon, Oct 27, 2008 at 9:39:24 AM | Mass not showing completely
Suzque
The mass icon button is chosen but when exporting the mass doesn't show at this point.  You also mention VG, what's this?
Mon, Oct 27, 2008 at 10:34:15 AM | Mass not showing completely
4 Stars: 203 Votes
VG= Visibility/Graphics, type VG then a menu with "Model, annotation, imported" show up, in model down until you see "Mass", by default it's uncheck, pick to check On...
Mon, Oct 27, 2008 at 10:44:16 AM | Mass not showing completely
Suzque
Typhoon - thanks!  Here are the images of the 3D view as well as one elevation.  Again, thanks very much for your help!
Mon, Oct 27, 2008 at 10:45:54 AM | Mass not showing completely
Suzque
YIKES!  After I viewed the attached images the elevation view shows the entire mass but on my screen is does not...
Mon, Oct 27, 2008 at 10:48:52 AM | Mass not showing completely
Suzque
OK, sorry... try this image.  I had added lines and a filled region to resemble the mass and then hid them in view.
Mon, Oct 27, 2008 at 11:46:00 AM | Mass not showing completely
4 Stars: 203 Votes
That "blue" roof is a "Mass"? go to Massing menu and pick in "Roof by face", select the faces of the roof you want, then in properties of that "New" roof you can change the tickness, material, components and so one, ONLY use the "MASS" to create forms easly and fast, then apply "walls, floors, roofs, curtain system", every time you open your project you have to check VV (mass) and so one.... Sorry (i must tell this soon) but i think the problem it's other....
Tue, Oct 28, 2008 at 7:44:48 AM | Mass not showing completely
Suzque
Sorry, I don't understand...
Thu, Oct 30, 2008 at 11:06:45 AM | Mass not showing completely
justinm
try this thread...this may be your issue
http://www.revitcity.com/forums.php?action=viewthread&thread_id=8482
Thu, Oct 30, 2008 at 11:51:17 AM | Mass not showing completely
#13
Suzque
Thanks... I give it a whirl!
Mass Floors not all showing up - some missing
Wed, Apr 11, 2012 at 4:44:47 AM
massing - default color not visible
Tue, Jun 9, 2009 at 9:28:38 AM
Mass object not showing
Sun, Aug 10, 2008 at 12:07:29 AM
Mass not showing up
Mon, Feb 18, 2008 at 9:35:35 AM
Cutting a section through a mass
Sat, May 16, 2020 at 4:21:55 AM
Page generation time: 0.5681
