68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Attching objects to a toposurface
Fri, Oct 24, 2008 at 6:48:35 AM | Attching objects to a toposurface
is there a way to attach an object such as a side-curb or a rpc object to a topo surface which is sloping (except for viewing it from all elevations and then moving it accordingly)? I do not know how to make my curb fall with the sloping surface and this seems to take ages manually.
Fri, Oct 24, 2008 at 7:38:39 AM | Attching objects to a toposurface
Site "is the weakest link" in REVIT at this time.  You can not do what you want - you end up having to do in place families or use walls and edit the profile.
Fri, Oct 24, 2008 at 8:05:07 AM | Attching objects to a toposurface
Thanks WWhub, not what I wanted to hear but maybe Revit 2010 wil have this option.
Fri, Oct 24, 2008 at 8:20:06 AM | Attching objects to a toposurface
4 Stars: 203 Votes
I don't know if this is what do you need but, pick in the family you want (rpc...) pick in "EDIT", in Settings-Family and category parameters choose "Site" and uncheck "Always vertical", save and load to project...
Fri, Oct 24, 2008 at 10:07:16 AM | Attching objects to a toposurface
jmbitzer81
 WWHub is correct, the site tools in Revit are horrible to use.
However, I have attempted this work around a couple time. In order to get my curbs, sidewalks, etc to follow the slope of my topo, I use a floor or a pad.  Then slope the floor to match my topo by editing the corner elevation points.  To make sure my curb is at the correct elevation, I use the spot dimension tool on the topo, and then edit my floor to match (+ the appropriate curb height).
Hope that makes some sense.
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface in Elevations
Thu, Aug 27, 2009 at 1:51:06 AM
what is the easy to do toposurface
Mon, Feb 27, 2006 at 8:44:07 AM
14
Toposurface
Tue, May 11, 2010 at 9:04:45 AM
Page generation time: 0.4280
