54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Cantilevered roof cable an brackets
38 Posts No Rating |
Im trying to make the brackets and cabel that holds up teh cantilevered roof on my building. does anyone know how to go about making a family for that? my approach is making the brackets seperately. i have the horizontal adn the vertical. i created parameters to adjust its hieght adn sitance from one another. i need to make the cable wire part of it. i want the ends of the cabel wire to be bases at the brackets so taht when i adjust the height and/or length of the brackets from one another that the cabel wire will strecth/shrink and adjust its angle to always remain based at teh brackets. any suggestions?
Hi, in the same family you can create 2 types, 1 for Cantilevered and the second type for brackets, then create in each other a "Visibility" parameter (Yes/no) so you can control the visibility in the family what do you want to see, but if you go to the "Tutorials" from autodesk you have there a "Family tutorials" and has an example with this...
Tension Cable |
Sun, May 27, 2012 at 6:54:39 AM
How do you make cantilevered Roofs? |
Mon, May 15, 2006 at 7:17:59 PM
Detail Lines in Brackets? |
Thu, May 6, 2010 at 12:38:47 PM
How to do Cable Tray with Real Material Color (Not just filter color) |
Wed, Feb 18, 2015 at 3:14:07 AM
Cable tray tee |
Tue, Nov 1, 2016 at 7:29:06 AM
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
