117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> How do you add Window Elevation to Window Schedule
Thu, Oct 23, 2008 at 11:09:19 PM | How do you add Window Elevation to Window Schedule
bkidman
Hello,
 Is it possible to add the Window front Elevation to a Window shedule and have the Fields Vertical down the page.
 See an attached example that I am going for.
 Thanks
Fri, Oct 24, 2008 at 7:12:20 AM | How do you add Window Elevation to Window Schedule
Sorry - you can not add graphics to a schedule and data in a schedule at this time is only in rows.
Fri, Oct 24, 2008 at 11:08:27 AM | How do you add Window Elevation to Window Schedule
Dafpfy
3.5 Stars: 11 Votes
you could use a legend for that, with custom windowtags or something
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thu, May 24, 2012 at 4:21:47 PM | How do you add Window Elevation to Window Schedule
daralkwadir
3 Stars: 1 Votes
yes... search the web for dynamic legend by t4revet
Fri, May 25, 2012 at 10:52:34 AM | How do you add Window Elevation to Window Schedule
rod23
5 Stars: 4 Votes
The "Legend Component" in a legend will have the front elevation of the windows in your project.  Dimensioning to reference planes will not work, so you've got to put <invisible lines> in the OOTB windows to get your dimensions right with the Legend Components.  You can do a presentation similar to what you posted, but the schedules only work in rows.
http://www.turbosquid.com/Search/Artists/Revitaoist
Elevation View for Window Schedule Not Dimensioning
Fri, Sep 12, 2008 at 3:01:10 AM
How to associate window to a room in window schedule
Fri, Oct 1, 2010 at 10:32:13 AM
Window sashes with different window numbers in the window schedule
Tue, Mar 19, 2024 at 11:49:54 AM
Combining Door & Window Schedule; it WORKS!
Wed, Jan 20, 2016 at 10:15:29 AM
Window schedule
Wed, Apr 18, 2007 at 5:28:37 AM
Page generation time: 0.8182
