54 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Elevation Bubble not showing in Enlarged Plan
I am currently working in Revit Architecture 2009 and having problems generating an interior elevations from an enlarged view. I have created a callout of my area in the 1/8" plan and I switch to the 1/4" plan and select "View" the option to insert an elevation is grayed out. Does anyone have any suggesttions to get this option back? I have created a new new file from the base template and it works just fine. I have compared the setting between my project and the base file in revit and all the settings seem to match.
You created a detail view - you can not place elevations in detail view. When you make your callout, choose floor plan.
That worked a lot better thanks for the help.
Detail Bubble Callout Options? |
Thu, Aug 13, 2015 at 3:54:17 PM
Interior Elevation References |
Thu, Jun 28, 2007 at 8:27:06 AM
Multi Segment Grid Line Bubble Issue |
Wed, Dec 11, 2013 at 2:52:11 PM
Grid bubble in elevation |
Sat, Oct 4, 2014 at 3:20:57 PM
Problem with Column bubble tag |
Mon, Sep 14, 2009 at 3:46:07 PM
Members: | 2022559 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
