80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Mechanical Shaft help
Thu, Oct 23, 2008 at 8:13:20 AM | Mechanical Shaft help
jasonr
I am working on a rather simplistic floor / basement combination plan.  I have incorprated the floor systems in the building and have cut the shaft locations for the mechanical equipment.  Is there any way that I can get these shaft openings to display and print on my basement plan?
Sat, Nov 1, 2008 at 7:52:07 AM | Mechanical Shaft help
tim123
4 Stars: 19 Votes
Select the shaft and go to its element properties.  You can set the level for the base and set an offset if you need it to go below this.
Mechanical Objects
Tue, Nov 29, 2005 at 12:39:39 PM
shaft cutting beams
Tue, Jun 2, 2009 at 7:47:18 AM
Round Shafts
Wed, Dec 17, 2014 at 6:39:01 AM
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:48 PM
Shaft Problem
Thu, Jul 12, 2012 at 5:20:52 PM
Page generation time: 0.2339
