110 Users Online (108 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Converting ArchiCAD objects into Revit families
Wed, Oct 22, 2008 at 4:18:15 PM | Converting ArchiCAD objects into Revit families
Moore44
Greetings all,
In your expierences have you found a way to convert ArchiCAD objects into functional Revit families? Can this be done in an effecient manner?
Thanks
Thu, Jan 17, 2013 at 6:33:55 AM | Converting ArchiCAD objects into Revit families
joekozelka
hello,
Just a guess. it would follow the same process of converting a Sketch up model into Revit by finding a third program that Archicad will convert to. For example convert Archicad into a DWG then loading the DWG into Revit and editing it from there. Look for Convert Sketchup to Revit. I am not familier with Archicad.
Let me know how you get on.
Joe
Thu, Jan 17, 2013 at 9:43:30 AM | Converting ArchiCAD objects into Revit families
joekozelka,
I think he did something else in the past 5 years!
Converting a Revit v 8.0 file into Archicad v10.0
Tue, Mar 24, 2009 at 4:21:52 PM
Converting 3D objects from ADT to Revit families? Any suggestions?
Wed, Nov 22, 2006 at 11:35:49 AM
Ex Archicad users
Mon, Oct 10, 2005 at 12:53:08 AM
Revit vs. Archicad [ 1 2 ]
Fri, Sep 28, 2007 at 11:57:55 PM
15
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:59 AM
Page generation time: 2.2692
