57 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> toggle annotation
39 Posts No Rating |
is there a way to make a keyboard shortcut to toggle all annotation on/off in a view? is there a way to move the annotation tab on top of the modeling tab in the view/graphics dialogue window?
admin
I don't think you can move the annotation tab...but you might be able to make a macro to turn off all annotations using a journal file. I've used journal files to open a file, export all my schedules out, and close the file so you might be able to do that with the annotations. I'm not sure if you can run journal files from within the program though.
Hiroshi Jacobs
The Catholic University of America |
62 Posts No Rating |
So far we haven't found a way to run a journal file within a session. It is possible to run a journal that doesn't close at the end though.
How to create toggle-able annotation into a face based family for plan view only |
Tue, Aug 23, 2016 at 2:30:16 PM
dimension centerline toggle |
Fri, May 23, 2014 at 2:30:28 PM
Conditional toggle yes no formula |
Thu, Mar 3, 2016 at 11:43:05 AM
Professional Seal on Revit Title Block |
Sat, Apr 18, 2020 at 1:03:42 AM
Annotation Object Styles [ 1 2 ] |
Thu, Dec 17, 2009 at 11:56:38 PM
15
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
