29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> curtain walls make like partition walls
Wed, Oct 22, 2008 at 12:43:50 PM | curtain walls make like partition walls
3drulez
4.5 Stars: 2 Votes
hi, i want to make up a partition wall that has got cement board panels on either sides and mullion framework sandwiched in between. the panels need to be flushed with each other so that from either sides the mullions are not seen . how to do it.
have tried making panels frm the template , but the panels dont flush . system panels have got some special property which i dont know but they flush with each other when the offset goes beyond the mullion width but panels made by families dont flush.
Wed, Oct 22, 2008 at 12:50:52 PM | curtain walls make like partition walls
4 Stars: 201 Votes
"i want to make up a partition wall that has got cement board panels on either sides and mullion framework sandwiched in between. the panels need to be flushed with each other so that from either sides the mullions are not seen" I don't understand, can you put some screenshots to figure out???
Wed, Oct 22, 2008 at 11:34:27 PM | curtain walls make like partition walls
3drulez
4.5 Stars: 2 Votes
iam sending a cad file so that you understand better the assembly.
its basically a partition board.
Thu, Oct 23, 2008 at 4:17:46 AM | curtain walls make like partition walls
4 Stars: 201 Votes
Hi, you can adjust the mullions position (in front, middle, back) of the glass panels(cement), you also has the parameter "Adjust for mullion size"...
I make a video today for you when i have possibility...
Hi again, see the video: http://screencast.com/t/EAkNuDEVa4
Edited on: Thu, Oct 23, 2008 at 1:08:44 PM
Sat, Oct 25, 2008 at 12:29:28 AM | curtain walls make like partition walls
3drulez
4.5 Stars: 2 Votes
hi,
i saw the video u uploaded .. i saw that u edited the system panel and then removed the default glazed ones .. thats a grt idea . thanks .
but one of my problem also is how to have the panels on either sides of the framework.
see if you can solve that .
Sat, Oct 25, 2008 at 4:00:59 AM | curtain walls make like partition walls
4 Stars: 201 Votes
Hi, i don't remove the glazed, i just put them in a "Empty system panel"...
about "but one of my problem also is how to have the panels on either sides of the framework" like what? "Double Glass"?? and you don't want the "Concrete panels"? All system with "Double Glass"?Or double glass in top and double panel bottom??
Edited on: Sat, Oct 25, 2008 at 7:13:35 AM
Sat, Oct 25, 2008 at 11:25:36 AM | curtain walls make like partition walls
3drulez
4.5 Stars: 2 Votes
yes i got it .. ie empty panels .
umm.. but  both sides means concrete panels oneither sides . i think the best way i can tell you what i need to do is by sending you a 3d image frm skp .
Sat, Oct 25, 2008 at 4:30:50 PM | curtain walls make like partition walls
4 Stars: 201 Votes
Hi, it's very simple to do that, you must create a "Curtain wall Family" where you can include or not, the mullion then in your project when you create a curtain wall you must choose in "Curtain Panel" this family, there are several ways to do this, i do this a few hours ago but i can't upload the video because i have problems with the JING program, i don't know but i think it's in "Screencast.com" where i have the video files and "He" don't let me upload the files...
Edited on: Sat, Oct 25, 2008 at 4:41:36 PM
Edited on: Sat, Oct 25, 2008 at 6:18:54 PM
Sun, Oct 26, 2008 at 2:03:28 AM | curtain walls make like partition walls
3drulez
4.5 Stars: 2 Votes
hey, i have tried what u showed but there is some mistake i make in either locking the planes or the parameters. i want the panels to flush .wirth each other as u see in the skp. but as i add the mullions the panels dont flush . the mullions show from the gaps .
i am uploading the revit file . plz see it .
 i know i am taking a lot of your patience. but sorry , i am a new learner.
Sun, Oct 26, 2008 at 2:08:14 AM | curtain walls make like partition walls
3drulez
4.5 Stars: 2 Votes
this is the uploaded file .
Sun, Oct 26, 2008 at 3:21:26 AM | curtain walls make like partition walls
4 Stars: 201 Votes
Hi, i see the email and i download the file, you work with RAC 2008 and i was working in this model in 2009 so i must create a new one in 2008 or change your model, i gonna take a look...
Edited on: Sun, Oct 26, 2008 at 7:09:26 AM
Sun, Oct 26, 2008 at 9:23:37 AM | curtain walls make like partition walls
4 Stars: 201 Votes
Hi "3drulez" i just send you a email with 3 videos explain the whole process, i hope you understand...
Partition walls [system family]
Wed, Dec 9, 2009 at 10:25:41 AM
Angled Curtain Walls - fillets and nested
Thu, Apr 23, 2009 at 5:42:47 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Curtain walls
Mon, Nov 7, 2011 at 10:28:33 AM
Curtain Walls
Wed, Apr 16, 2008 at 1:30:46 PM
Page generation time: 1.1409
