49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> piping in plan view
Wed, Oct 22, 2008 at 12:39:29 PM | piping in plan view
lt0781
I am doing my first project in revit and was wondering how overlapping piping in plan view could be shown so they didn't look like they were all connected together?
Wed, Oct 22, 2008 at 1:43:00 PM | piping in plan view
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
fine+hidden line... you may need to adjust your mechanical hidden line settings... depends on the scale of the plan. although if your doing plumbing you may want to use course+wireframe
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Wed, Oct 22, 2008 at 2:59:35 PM | piping in plan view
lt0781
thanks for the quick response. i've tried making the outside gap larger but it doesn't seem to do anything. is there a specific linetype i should be using so that it shows?
Thu, Oct 23, 2008 at 10:35:28 AM | piping in plan view
Eddieboarder91
4 Stars: 8 Votes
are you doing mechanical piping or plumbing? if it is plumbing i suggest creating new line types (perhaps ones that match your previous standard, you can also import them to a drafting view and when you explode the dwg the line types get added to your line types in revit...pretty convient i say) that then the pipes can be overriden in plan with the use of filters... mechanical piping on the other hand...generally much larger... in your mechanical settings what is the line style? mech hidden? hidden line? lines? i set mine to mech hidden... it really all depends on what you want to see... also something i just thought about too is it really depends on what view you have created to view this piping...if it is an rcp (revit does a true rcp) we have been actually using floor plans for out mechanical plans to get the hvac to show correctly.
hth
Tue, Mar 17, 2009 at 9:09:25 AM | piping in plan view
lt0781
ok, i've got the hidden lines to work for double line ductwork but for the life of me i can't get my plumbing piping to break either in course or fine setting. i've tried all different combinations of view settings (i.e. course/hidden ....). the one thing i've noticed is that as i was increasing the gap settings for the hidden lines the overlapping pipes wouldn't do anything but the gap would show around fittings (i.e. floor drains). this problem is kicking my butt! thanks in advance if anybody has any other ideas. i'm empty.
some pipe fittings and piping now showing below floor
Thu, Apr 9, 2020 at 6:46:14 AM
Piping loops
Wed, Apr 30, 2008 at 12:36:00 PM
Connecting Sanitary Piping
Thu, Dec 13, 2012 at 3:42:24 AM
Adding materials to piping systems
Mon, Oct 12, 2009 at 4:07:43 PM
REVIT for process piping spool drawings?
Mon, Mar 5, 2012 at 1:54:10 PM
Page generation time: 1.6494
