66 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> HELP!! Wall problems (Revit 09)
Wed, Oct 22, 2008 at 12:23:15 PM | HELP!! Wall problems (Revit 09)
jcallis
Hello Everyone,
 I am working on a residential renovation and i have the drawing split up into phases: Existing, Demolition, and New Construction. When I draw a wall and then erase it, it doesnt go away everywhere. It will delete on the first floor(where it was drawn) but it still shows up in: elevations, 3d elevations, second floor w/ first floor underlay, etc. EVERYWHERE. So when I try to redraw a wall in the same location it says the following: (Highlighted walls overlap. One of them may be ignored when Revit finds room boundaries. Use Cut Geometry to embed one wall within the other.) And the new walls wont clean up.
Anyone know how to help me?
 Thanks,
Justin
Wed, Oct 22, 2008 at 12:24:54 PM | HELP!! Wall problems (Revit 09)
jcallis
Also, there is nothing above it on the second floor or below it on the basement.
Wed, Oct 22, 2008 at 1:09:01 PM | HELP!! Wall problems (Revit 09)
blake
3 Stars: 2 Votes
Check your phase filter.  Change it to previous and new and see if that works.
Wed, Oct 22, 2008 at 1:17:26 PM | HELP!! Wall problems (Revit 09)
jcallis
Sorry, but how do you change your phase filter so that it only shown existing and new construction? When I pick that filter and pick apply it does nothing.
Wed, Oct 22, 2008 at 1:25:22 PM | HELP!! Wall problems (Revit 09)
blake
3 Stars: 2 Votes
One thing that we have done was not use the demo phase.  We just demo things in the new construction and then that should work.  So I might have miss told you.  But if you are using all three phases double check that your are demoing and drawing things in the right phases.  You can do so by clicking element properties.
If you go to Setting>Phases... then to the Phase Filter tab that will show you what shows up in each filter and you can create your own to display how you want it to display.
Wed, Oct 22, 2008 at 1:35:52 PM | HELP!! Wall problems (Revit 09)
jcallis
Thanks for your help Blake. I was reading this article on phasing and it says that the number one mistake architects make is that they set up a phase for demo.
Wall Join Problems [ 1 2 ]
Tue, Feb 23, 2010 at 1:21:21 PM
15
Wall Trim Command Problems
Wed, Jul 14, 2010 at 12:47:16 PM
wall wrapping problems
Wed, Mar 4, 2015 at 9:59:03 AM
2016 Stacked wall problems
Tue, Apr 5, 2016 at 12:03:49 PM
Problems with Stacked walls
Mon, Dec 21, 2009 at 3:01:21 PM
Page generation time: 3.3202
