75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stacked wall problem - corners do not fillet.
Fri, May 6, 2005 at 12:24:23 PM | Stacked wall problem - corners do not fillet.
bearcjs22
If I create a stacked wall consisting of a masonry base with 500mm offset 70mm thick cladding externally, the corners of the cladding do not fillet. However, if I then edit the stacked wall and change the cladding offset to 0 and the wall style to match that of the base, the walls will now fillet. Now if I offset the wall again by 500mm the cladding is fillited, and then if I change it back to cladding (as per the original wall style that wouldn't fillet) it stays fillited? Has anyone else had this problem? Please help. Kind regards Chris
Fri, May 6, 2005 at 7:36:23 PM | RE: Stacked wall problem - corners do not fillet.
SCOTTY V
hey there, I opened this up and had no trouble with it. i tried a few of different placements, all fillited the wall. Sorry I can help
Sun, May 8, 2005 at 6:03:33 PM | RE: Stacked wall problem - corners do not fillet.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I have experienced this. You can correct these instances by manually adjusting the wall joins. That is dragging the end point of each wall at an intersection away slightly (not to much that causes them not to join at all). This will correct the wall join, make sure you do it for all walls at the intersection. HTH.
Mon, Jun 13, 2005 at 6:35:18 PM | RE: Stacked wall problem - corners do not fillet.
Tamas
This problem has been fixed in one of the later 8.0 builds. Probably this is why Scotty V did not see it. Tamas
Wed, Jul 16, 2008 at 10:23:24 AM | Stacked wall problem - corners do not fillet.
echo1
I am having issues with this in Reit 9.  Are there any new solutions?  TIA!
Wed, Jul 16, 2008 at 11:40:40 AM | Stacked wall problem - corners do not fillet.
echo1
Sorry, I meant to say revit 2009.  I Unjoined and rejoind the walls and that fixed a lot, but I still see a gohsting of the interioir studs on the adjacent walls exterior face.  Odd.
Fillet arc not working on baluster panel extrusion
Wed, Oct 26, 2011 at 5:56:35 AM
Stacked Wall with sloping/rounded edges questions
Fri, Jun 20, 2014 at 11:41:21 AM
Roof Footprint - Fillet corners
Fri, Oct 14, 2011 at 12:17:58 PM
3D Fillet/Chamfer
Thu, Sep 2, 2010 at 5:31:43 PM
Fillet to wall
Sat, Apr 16, 2011 at 9:14:47 PM
Page generation time: 1.9382
