74 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Beam & Beam systems
Tue, Oct 21, 2008 at 3:30:52 PM | Beam & Beam systems
PPLACKO
I am working on a framing plan, when I place a beam system will show up, but if I use a Beam won't show up on the plan, How should I make the beam to show on plan? I tried line work, it doesn't work, I checked level and it is the same as the beam system, I don't understand why beam system shows but an individual beam doesn't . Any ideas???
Thank you
Tue, Oct 21, 2008 at 4:36:54 PM | Beam & Beam systems
4 Stars: 201 Votes
try in the view plan you want to see the Beam, go to VP and in "view range" change the parameters like you can see in the images attached, also in VG, go to "Structural Framing" in the "Projectio/surface lines - Override" you can change the color, weight and pattern...
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Beam Systems
Wed, Aug 13, 2008 at 11:42:00 AM
Sloped Beam Systems Q's
Mon, Nov 14, 2016 at 11:48:46 AM
Non-Planar/Sloped Beam Systems with Elevation Points?
Thu, Jun 14, 2007 at 12:11:36 AM
Beam Systems
Wed, Feb 8, 2006 at 2:00:42 AM
Page generation time: 0.6022
