43 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Help required with portal frame buildings
4 Posts No Rating |
I currently design and detail portal framed buildings such as retail parks, warehouses, foodstores etc...
Has anyone got a portal frame family that works? I am struggling to create the steelwork associated with the building.
I need some guidance as to how to develop steelwork which can be used easily and adapted under various designs as so far the structural package is not user friendly.
I would also appreciate it if anyone constructing similar steel framed structures could advise how they succesfully manage to produce such buildings.
Any advice would be greatly appreciated.
I have an operating parametric portal frame but i try not to upload everything i create. Try to give my office some benefit of having me here...
I'll see what i can do...
40 Posts No Rating |
This area is one of the weakest links of Revit i've been raising this issue since version 5 . The current procedure is to create a parametric frame through sweep and extrusion but for structural function this is not revit like as it has no ref whatsoever to the actual steel database that we have built-in in revit. Say for example if you have a tapering frame column from one WF size from one end then another WF size on the other end you have to input the properties of the WF section manually in revit. This is easily done in ADT since version 3.3 just click the section from the dababase then its done with correct properties from AISC database of steel sections.
I don't know if this works already like a charm in Revit Structures we'll wait and see.
portal frame |
Thu, Aug 6, 2009 at 8:41:32 PM
UK - looking for a parametric steel portal frame for a factory unit! |
Tue, Apr 19, 2005 at 11:06:43 AM
Portal Frames |
Mon, Jun 19, 2006 at 2:10:53 PM
Parametric Custom Portal Frame - please help $offered |
Tue, Sep 22, 2015 at 7:30:30 PM
top primary range |
Wed, Jul 7, 2010 at 12:51:55 AM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
