83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> misguided underlay
Tue, Oct 21, 2008 at 8:37:09 AM | misguided underlay
middleton
hey gang,
recently weve had an issue come up where several of our projects are showing the ceiling plan of the plans we are trying to underlay rather than the plan itself.  or put another way, when we underlay the floorplan, we get floorplan-ceiling plan as an underlay instead.  and its the same for all the levels.
 any ideas?
 thanks in advance!
Tue, Oct 21, 2008 at 9:55:56 AM | misguided underlay
KingRevit
4 Stars: 12 Votes
is your underlay orientation set to reflected ceiling plan? this is the set in your view properties
Tue, Oct 21, 2008 at 10:51:59 AM | misguided underlay
middleton
no, its set to 'plan' and the view range of all views has been to their default associations
Tue, Oct 21, 2008 at 12:41:54 PM | misguided underlay
KingRevit
4 Stars: 12 Votes
have no other idea as it works fine for me, i know that is no help for you. stip down your model and upload it and i'll have a look at it.
Tue, Oct 21, 2008 at 12:53:01 PM | misguided underlay
KingRevit
4 Stars: 12 Votes
before you upload the file have you tried turning your ceilings off in your visibility graphics
Tue, Oct 21, 2008 at 1:21:46 PM | misguided underlay
middleton
no, but while that does get rid of the ceiling, yes, it doesnt change the fact what is underlaying is the ceiling plan rather than the plan.  and in areas where the wall structure above sut plane is different is than at floor level, this will not fix.  also, this same 'glitch' is occuring in all views, so its not just ceilings that are showing in all cases.  for example (and i know this is something that would only be done to test an instance like this), underlaying the site plan below the floor plan shows the roof, rather than the site.
 we got a note into autodesk on it, and ill update here if they come up with anything.
 in the meantime, any other guesses?
 this is the first time ive ever seen this particulat issue
Tue, Feb 2, 2010 at 10:53:49 AM | misguided underlay
carmer
I know this post is a year and a half old...but was there ever a solution discovered?  I have this problem occasionally too.  View ranges are all set to defaults.  When I try to underlay the first floor in a basement view I am getting the second floor ceiling as an underlay.
Tue, Feb 19, 2013 at 8:14:29 AM | misguided underlay
dargaly
4 Stars: 5 Votes
hello ,,i need to know if its possible if i want to hide the part of the underlay plan underneath my current floor n show the outer parts only ??
Underlay
Thu, Oct 11, 2012 at 8:15:33 AM
Underlay is not working
Mon, Apr 28, 2014 at 5:29:50 PM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
wrong underlay showing
Mon, Jan 27, 2014 at 1:29:57 PM
underlay
Mon, Aug 11, 2008 at 6:18:01 PM
Page generation time: 0.2461
