42 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Help with brick hatch
Tue, Oct 21, 2008 at 4:29:55 AM | Help with brick hatch
juul
Hi
I'm struggling with converting an imperial brick pattern to millimeters. The pattern should be a running bond with the brick dimension: length 226mm, height 60mm and mortars: 14mm vertical and 15mm horizontal. (the brick module is 240x75). I find the autoCAD help file very difficult to work out. I wonder why they haven't made the procedure more grafical yet?!?!
this is the patternfile I used as a sketch:
0,      0,  0,  .25,.2,  .47,-.030,      0,.17,  .25,.2,  .47,-.0390,     0,  0,  .2,.25,  .17,-.2390,  -.03,  0,  .2,.25,  .17,-.23
 Thanks!
 -Lasse
Thu, Oct 23, 2008 at 6:13:44 PM | Help with brick hatch
psymon
psymon Avatar
3.5 Stars: 6 Votes
look, at the end of the day, no-one doe, there are far better things to do with your time.
I have attached a model version for you, the things to note in the file are the line telling Revit that it is metric and a model pattern
HTH
Fri, Oct 24, 2008 at 2:21:12 AM | Help with brick hatch
juul
Thanks Psymon!
 And you are totally right! And in addition you also master the hatch-nonsense. Sometime I really wonder when (or if)  Autodesk will MAC-simplify their programs, so their customers will get a true userfriendly and easy learning-and-doing environment...
 ...Again: thanks! The world would be a cooler place with more people like you!
Fri, Oct 24, 2008 at 5:17:09 AM | Help with brick hatch
juul
Hi Psymon
 I've looked at the hatchpattern you did for me, which was fine since it had the rigtht overall proportions, but the real troubble I'm dealing with, is how to add mortars in the pattern. This simply won't work out for me...
Sat, Oct 25, 2008 at 7:08:02 PM | Help with brick hatch
mgr2820
2 Stars: 2 Votes
Download a cad hatch creator like hatch manager from globalcad. You can draft your hatch in autocad, export the .pat, then add the script line that will allow it to work in revit.
Sun, Oct 26, 2008 at 10:26:47 PM | Help with brick hatch
hugh
3.5 Stars: 4 Votes
Note a "soft" conversion is done when loading a model pattern specified in inches into a metric environment - ok  for stone but not metric bricks.  This pattern should work for you
;%VERSION=3.0;%UNITS=MM*NEW;%TYPE=MODEL;-------------------------------------------------------------------------------;        Pattern written by HatchKit v2.7 Hatch Pattern Editor;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2008.;        www.cadro.com.au/hatchkit/;-------------------------------------------------------------------------------;-Template=NEW,;-Source  =C:\Documents and Settings\Hugh\Desktop\NEW.PAT;-Date    =27/10/2008;-Time    =3:08:25 PM;-HatchKitVersion=2.7.1.2013;-------------------------------------------------------------------------------180,226,0,120,75,226,-14180,226,60,120,75,226,-1490,226,0,75,120,60,-90-90,0,60,75,120,60,-90
Hugh Adamson
www.hatchkit.com.au
Sun, Oct 26, 2008 at 10:31:04 PM | Help with brick hatch
hugh
3.5 Stars: 4 Votes
Whoops, I'd forgotten about the pitfall surrounding cut and paste - try the attached file.
Hugh Adamson
www.hatchkit.com.au
Mon, Oct 27, 2008 at 4:01:06 AM | Help with brick hatch
juul
wow!
I'm starting to love Revitcity nearly as much as my wife, thanks to all the helpfull peolpe on this site!
Sincerely
Juul
Mon, Oct 27, 2008 at 5:44:32 AM | Help with brick hatch
puzzle
4 Stars: 10 Votes
nice brick pattern hugh. just wondering if you had one for a 240x75mm brick setup
240mm + 10mm mortar
75mm + 10mm mortar
thanks
Macca
Sunshine Coast
QLD Australia
Mon, Oct 27, 2008 at 7:12:49 AM | Help with brick hatch
hugh
3.5 Stars: 4 Votes
Sure.
Using HatchKit,
  • draw a line from 0,0 to 240,0 then continue to 240,75 then to 0,75 and finally to 0,0 (or C to close).
  • Adjust the pattern repeat vector endpoints to 0,250 and 125,85
  • Name the pattern and save as Revit Metric Model
Result will be like this:
  • ;%VERSION=3.0
  • ;%UNITS=MM
  • *240X75+10,240x75 brick, stretcher bond
  • ;%TYPE=MODEL
  • ;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
  • ;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2008.
  • ;        www.cadro.com.au/hatchkit/
  • ;-HatchKitVersion=2.7.1.2013
  • -90,0,75,85,125,75,-95
  • 180,240,75,125,85,240,-10
  • 90,240,0,85,125,75,-95
  • 0,0,0,125,85,240,-10
If you cut and paste this pattern to a text file it should work. Just in case, it's also attached.
Hugh Adamson
www.hatchkit.com.au
Mon, Oct 27, 2008 at 5:12:33 PM | Help with brick hatch
#11
puzzle
4 Stars: 10 Votes
thanks hugh,
much appreciated
Macca
Sunshine Coast
QLD Australia
Mon, Oct 27, 2008 at 5:39:37 PM | Help with brick hatch
#12
hugh
3.5 Stars: 4 Votes
No worries.
We're currently a bit short on rain - any going spare up there?
Hugh Adamson
www.hatchkit.com.au
Hatch pattern on a wall
Thu, Mar 29, 2012 at 9:00:22 AM
1/3 course norman brick hatch
Wed, Jan 5, 2011 at 3:58:32 PM
HATCH 22- REVIT MODEL HATCH
Fri, May 8, 2015 at 3:01:05 AM
Sloped Hatch Pattern
Fri, Oct 2, 2009 at 1:57:20 PM
Complex Brick Pattern Elevations
Thu, Jul 10, 2014 at 6:11:25 PM
Page generation time: 0.2493
