133 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Text On A Retail Sign
Thu, May 5, 2005 at 7:34:38 PM | Text On A Retail Sign
Cypher
Good Evening Everybody, I put a retail sign at the front of my house. I put a text on it but I can't see it anymore after rendering. How is it possible to be able to keep it after rendering? Thx a lot Cypher
Thu, May 5, 2005 at 9:07:40 PM | RE: Text On A Retail Sign
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
So you've applied a decal to a surface for the sign? Decals will only show when rendered. If its not showing, check the decal properties to make sure the file location is correct or the image hasn't moved. You cannot show decals in non-rendered views. If its an elevation you wish to show just import the image and place in the appropriate location. If 3D unfortunately there isn't really a way.
Fri, May 6, 2005 at 3:21:59 AM | RE: Text On A Retail Sign
fazerneil
4 Stars: 5 Votes
Or if 3d text see extruded text query below.
ADA Sign - Text not showing
Tue, Sep 24, 2019 at 4:03:49 PM
Rendering Text
Wed, Dec 10, 2008 at 4:47:02 PM
Parametric Exit Sign
Mon, Apr 14, 2014 at 12:38:12 PM
13
Accidental Backwards Model Text
Fri, Jun 5, 2020 at 11:59:30 PM
Retail Architecture
Fri, Oct 21, 2005 at 3:30:55 PM
Page generation time: 8.2496
