48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Refreshing Imperial Library
Mon, Oct 20, 2008 at 3:55:53 PM | Refreshing Imperial Library
tinninttu
We have a revit template file that is used for all new projects. when we have edited or modified the imperial library, we need to reload or refresh the library into our template file so every new project is up to date with the current libraries. How do i reload this? Where do i go to do this.
Thank you
Stephanie Smile
Mon, Oct 20, 2008 at 7:17:45 PM | Refreshing Imperial Library
If you have changed a family after it has been loaded, you will have to open each family and re-load it into the template.
Tue, Oct 21, 2008 at 8:46:03 AM | Refreshing Imperial Library
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
My recommendation would be to keep as many families as possible out of the template, except for company standard specific families (i.e. door tags, window tags, etc.; as these shouldn't need to change very often once they are created) and have the users load them into the project as needed. The reasoning behind this are for the reason you have stated above; if you have a limited number of families in your project, then as you load them in as needed you can be sure you have the most up to date families. Another reason is to keep the file size of your template down, this will help load your template faster.
Good Luck,
cad.web.print
Tue, Oct 21, 2008 at 8:51:28 AM | Refreshing Imperial Library
tinninttu
Thanks for your responses. I understand what you are saying about the families and other components, but what i am trying to refresh are things like our MEP symbols, labels, and tags. Things that are our office standards and need to be refreshed. Thanks for your help, but if you have any other suggestions please let me know
Thanks again, Stephanie
Tue, Oct 21, 2008 at 9:10:15 AM | Refreshing Imperial Library
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
I that case I believe you would have to go with what WWHub has stated above.
Something worth looking into is the BIMContentManager from Digital Building Solutions. Is a little utility for Revit that allows you to organize and compare families within libraries and folders. By the looks of it though, the website looks a bit out of date, I'm not sure if they have an '09 release.
cad.web.print
Tue, Oct 21, 2008 at 9:17:50 AM | Refreshing Imperial Library
tinninttu
Ok, will do. Thanks so much Smile
Library Components, Metric and Imperial
Mon, Apr 30, 2012 at 12:39:00 PM
Imperial Library
Thu, Nov 9, 2006 at 4:59:33 PM
IMPERIAL LIBRARY
Mon, Apr 7, 2008 at 4:54:50 AM
update imperial library files
Mon, Mar 15, 2010 at 3:05:41 PM
Imperial Library Location
Wed, Feb 3, 2010 at 7:26:03 PM
Page generation time: 0.6227
