102 Users Online (101 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009: Mapping an aerial image to topography
45 Posts No Rating |
Hi all. My question is simple: Is there a way to map an aerial image (from google earth) on a topography object? Thanks to all!!!
![4 Stars: 202 Votes](/images/stars_4.gif) |
Hi, what do really want? create a topography site by an image of Google earth or insert an image (like a texture) from Google earth in your site already created?
Hi, I want to map an aerial photography (like a texture) on the site already created (toposurface). Thanks for your help. PS: I Think better site tools is the real improvement revit needs!
Hi, you can create a "Texture" and assign that "aerial Image" to the material of the topography BUT the problem is when you create a "site" you can see he create Contours and also divide the topo in "Faces", that's how the programs calculate the topography (by triangulation), so your texture-Image gonna be insert (divide) in ALL FACES, witch means, you have the same image in every triangule, and the other problem is the surface are not a regular (flat) "Slab", it's irregular (sloped) so you can't use a "Decal" on that.... i don't know if anybody solve this problem yet....
Why you dont make the oposite? Export the revit file to google earth. Regards
![Quantifier Avatar](user_avatar/47648.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
I think the best way to do this is use 3Ds max... I think 3Ds max lets you insert the "aerial view" onto your toposurface and will not calculate the surface by "triangulation" by converting your toposurface into an editable poly. not editable mesh/face which uses triangulation calculation. In other words, use polygon! Hope that helps... I have not done this myself... but i've seen this work in tutorials.
oops!.. I didn't realize it's an old thread. oh well.
Aerial Image Under Building in 3d |
Mon, Mar 10, 2008 at 2:03:56 PM
Geo-Mapping textures |
Sat, Aug 29, 2009 at 5:26:06 PM
Revit 2017 weird mapping in shape-modified floors |
Thu, May 11, 2017 at 11:56:49 PM
Circle hatch/mapping |
Fri, Dec 2, 2011 at 1:08:11 PM
Default file path for layer mapping files |
Mon, Sep 1, 2008 at 3:06:00 AM
Members: | 2081105 | Objects: | 23122 | Forum Posts: | 152272 | Job Listings: | 3 |
