127 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Repeating a building over and over, how to go about doing working drawings...
Sun, Oct 19, 2008 at 9:21:00 PM | Repeating a building over and over, how to go about doing working drawings...
archdm
we are doing a retirement complex and we are wanting to use the same building over and over so each set of working drawings will be pretty much the same except materials may change. Whats the best way to set this up? Can we link them so that they have the same information on each sheet except for the things that differ eg. details for different materials. or are we best to set up a different file for each building that has different materials and just copy and paste any similar information.
Any help would be much appreciatedSmile
Mon, Oct 20, 2008 at 9:38:13 AM | Repeating a building over and over, how to go about doing working drawings...
KevinKernaghan
If you're talking about changes to wall finishes, you could group all consistent walls and copy that over and over again, and then have another group with different wall construction for each finish/material option you want.  You can insert these material-option wall groups into your consistent groups and then your material takeoffs and scheduling will be correct.  You also may not have nearly as much stuff to change later on if a wall or door has to be moved.
Wall joins may not work as well though, so I would recommend trying it out on a small scale first.  I know there's definitely other options, perhaps some moderators can elaborate.
Updating town planning drawings from working drawings??
Thu, Apr 6, 2006 at 10:46:37 PM
Large scale projects with repeating rooms grouped...
Wed, Jul 25, 2007 at 8:48:43 AM
Editing instance of Repeating Component
Mon, Jan 13, 2014 at 12:12:26 PM
Casework: Repeating Element
Fri, Jul 18, 2008 at 6:39:40 AM
Using Revit Structure to produce Steel Fabrication Drawings (shop drawings)
Sun, Feb 24, 2013 at 1:00:01 PM
Page generation time: 0.6982
