Forums >> General Discussion >> Wishlist >> Detail Custom Text Change
2 Posts No Rating |
It's really been getting to me that every time I change the witness lines of a dimension I have to completly re-type my custom text. Would sure be nice if it stayed the same...
Can you be more specific about that issue (images)???
98 Posts No Rating |
He's talking about when, for example, you dimension to the finish face of two walls and use the new 2009 of adding text into the dimension to add "+/-" or "Approximately" and then decide you want the dimension to go to the center of the wall the text you added gets deleted. And I agree, it's very annoying.
2 Posts No Rating |
Explained very well. Thanks!
Oh, it's true, i check that... Wish list?
creating custom detail componets |
Wed, Jul 26, 2006 at 9:49:27 PM
custom section tag woes |
Tue, Jul 24, 2012 at 4:47:03 PM
Bi-directional linking with text possible? |
Tue, Feb 7, 2017 at 11:24:11 AM
Text Orientation in Custom Elevation Marker |
Fri, May 6, 2011 at 10:36:13 AM
custom viewport styles |
Tue, May 12, 2015 at 12:57:24 PM
Members: | 2114928 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
