37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall sweep splitting/joining
Sat, Oct 18, 2008 at 1:42:27 PM | Wall sweep splitting/joining
maranelloboy
3 Stars: 2 Votes
Is there a way to split or join a wall sweep?  For instance, I have a window that's broken up into three sections with fluted trim in between.  When I place my chair rail wall sweep on that wall, it shows up in the flutes because the openings stop at the edge of the window.  There are other instances where the wall I want a sweep on crosses several door ways for rooms that I don't want the sweep in.
Sat, Oct 18, 2008 at 1:49:09 PM | Wall sweep splitting/joining
4 Stars: 201 Votes
Hi, can you put some screenshots to figure exactly what really do you need?
You have that "blue dots" when you pick in the sweep and you can "Stretch" them to the position you want, you can "Join" them, use the "Join Geometry" command...
Edited on: Sat, Oct 18, 2008 at 2:02:16 PM
Sun, Oct 19, 2008 at 1:29:46 PM | Wall sweep splitting/joining
maranelloboy
3 Stars: 2 Votes
This wall is more doors and windows than wall.  I can stretch all the segments together on one end, but that's annoying.
Thu, Sep 14, 2006 at 12:48:51 PM
Wall sweep as footing join
Fri, Jun 8, 2018 at 2:20:58 PM
Parapet wall sweeps not joining
Fri, Oct 25, 2013 at 3:00:32 PM
gap in wall sweep without wall opening?
Thu, Apr 22, 2010 at 3:14:20 PM
Sweep problem
Wed, May 21, 2014 at 9:21:16 AM
Page generation time: 0.8508
