73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rendering Interior Light is not working, black screen.
Fri, Oct 17, 2008 at 2:24:36 PM | Rendering Interior Light is not working, black screen.
breyrw
When I try to render an interior scene, using a 3d camera view, with lights turned one, all it produces is a black screen.  I tried using the default 3d view and it renders a light scene.  Any ideas on why the lights will not render in a camera view?  I know they have worked before.  Thanks
Fri, Oct 17, 2008 at 3:16:21 PM | Rendering Interior Light is not working, black screen.
4 Stars: 203 Votes
Well, Revit Version? 2008? 2009? Settings of render??? can you put some screenshots to what are you trying to render and the settings you are using? Position of the camera? What kind of "Lights" you are using in that???
Sat, Oct 18, 2008 at 11:30:38 PM | Rendering Interior Light is not working, black screen.
breyrw
It is Revit Arch 2009, I figured out why they were not showing up.  The lights being used were recessed cans, and they were recessing into the roof that have, so there was no light coming through the roof.  But now that I have light another issue has come up.  When rendering an interior, the carpet turns out way brighter under the lights than it looks when I select the color.  Here are some shots.  The color in the dialog box is a lot darker than the color in the render. ???
Sun, Oct 19, 2008 at 6:12:51 AM | Rendering Interior Light is not working, black screen.
4 Stars: 203 Votes
Hi, change the "Brightness" value...
Wed, Nov 19, 2008 at 4:15:25 AM | Rendering Interior Light is not working, black screen.
MSkagen
Hi, how did you solve the problem with the "recessed cans"... I've the same problem...
I hope you can help. I need the light source to be from the spots, but can't get any of the available spot to work
Thu, Mar 18, 2010 at 11:56:32 AM | Rendering Interior Light is not working, black screen.
ookii
my problem is very similar, when scheme option is set to artificial lights on, every vertical surface seems to be black, and i dont mean a not iluminated wall, i tried by putting a lot of lights, by removing every light, but its senseless, the render continues like there are parts that are not being renderized. Also when i render with scheme option set in sun only (interior and exterior) theres no problem with black surfaces.ill apreciate your helpOki- Architect
Thu, Mar 18, 2010 at 2:46:03 PM | ookii
ArchAddict
Quoting ookii from 2010-03-18 11:56:31
"my problem is very similar, when scheme option is set to artificial lights on, every vertical surface seems to be black, and i dont mean a not iluminated wall, i tried by putting a lot of lights, by removing every light, but its senseless, the render continues like there are parts that are not being renderized. Also when i render with scheme option set in sun only (interior and exterior) theres no problem with black surfaces.ill apreciate your helpOki- Architect"
This sounds to me like your Material for the wall is set incorrectly. Double check your "Render Appearance" Settings and make sure they are not set to black or a really dark color. The Shading Appearance can be completely independent from the Render Appearance (and is be default).
A quick check would be to make a new material thats a very light color and paint that on a wall and do a quick draft test render. I know the shading appearance / Render appearance differences have caught be a few time on families people posted that started in Sketchup, the shading colors gets mapped but not the render color...
Thu, Mar 18, 2010 at 3:22:45 PM | Rendering Interior Light is not working, black screen.
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
There is a possibility that the phases that the ceiling and the recessed cans were created in are different.  They would still interact with each other--the cans will sit in a ceiling of a different phase--but not truly cut it.
Sat, Apr 30, 2011 at 8:29:29 PM | Rendering Interior Light is not working, black screen.
lganci1
Yup. I was having this problem. I had to go into edit type for the wall and go to the first tab; the tab before render appearance. Check the box off at the top that says" use render appearnace for shading" and retry rendering. It should work then.
Fri, Dec 14, 2012 at 9:26:38 AM | Rendering Interior Light is not working, black screen.
espitzer
The light will render no matter tha phase. if the phase of the ceiling is new construction and the light is existing(for whatever reson this may be) the light will still render!
lights not working in 3D or rendering
Thu, Jul 11, 2013 at 10:56:37 AM
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:29 PM
27
Interior Rendering Problem [ 1 2 ]
Tue, Jun 7, 2011 at 1:17:38 PM
17
Black rendering pictures
Sun, Sep 9, 2012 at 10:25:29 AM
INTERIOR RENDERING
Mon, Jul 9, 2007 at 1:02:32 PM
Page generation time: 2.6955
