Forums >> Revit Systems >> Technical Support >> topo surface causing slow performance
12 Posts No Rating |
I am working on a project where I'm building a relativley large site by using the toposurface command. As I add subregions to the toposurface however the program seems to grow increasingly slow. By this I mean that the creating or editing of a subregion takes about 10 minuts to get into and out of sketch mode. I am using a very high powered pentium 4 machine and cannot understand why regenerating would take so long. I know that it is the large topo surface that it is having a problem with but is there anything I can do to speed up the regeneration process? Is splitting the surface into different pieces the only way to solve this problem?
How large are your Project (in MB)? what caracteristics of your computer, Ram, O.S. (32 or 64 bits), Revit Version???
Edited on: Fri, Oct 17, 2008 at 10:27:32 AM
The Sspecs. on my computer are attached and the file size of the revit drawing is 71 MB.
revit 2009
Well, you have a Pentium III Xeon with 3.2Gb of Ram working in XP SP2 and your file has 71MB, it start to be a BIG file, make a BACKUP and "Purge" that file what don't you need, also "Close Unused Windows" in the TOP "Windows" menu....
thats a decent machine, i wouldnt consider it high power but god enough for some terrain mapping. What is the precision of your surface? anything over a dozen acres I only use major contours, anything over 150 acres I break up into segments.
The site is 233 acres and has a 500' change is elevation. My topo lines are placed at intervals of 2'. Is that too detailed? An image is attached.
Well, it's a BIG surface....
yeah thats pretty good size, i would simply the surface to a precison of 5' to 10' Other than that your best bet is to go 64bit OS with 64bit Revit.
and put RAM on that... (i think i gonna to a Workstation RISC 2xQuadCore2 64GB RAM
Reviving an old thread here. I'm also finding huge slow-downs with editing the topo ...we're modeling a HUGE chunk of town to show the extents of a university's land holdings, roughly 4 square miles of very low detail topo, with some regions of highly surveyed data.. currently it's one topo surface with many subregions, so I understand why it's slow, for sure. I was considering splitting it to make edits easier, but now I'm not sure because of this problem: I can't make new topo regions without experiencing the same ammount of delay. I've turned off everything in VG except one 2-D cad drawing, and closed all but one siteplan view that's heavily cropped. But still--at least two minutes to edit a NEW surface, 1 minute lag for each point placed or altered. I cannot explain this delay, since it's disassociated from the bulk of the project. File size is still just 30-40 megs. I'm running win 7 64bit on a machine with 16 gigs ram and 8 cores, it chews through anything else. Anyone have any experience withthis sort of scale, or this sort of slowdown?
Topographic surface linked vs. in model |
Tue, Mar 19, 2013 at 6:15:37 PM
Topo Surface Edits Running EXTREMELY SLOW in 2010. Help :) |
Mon, Jan 18, 2010 at 8:38:59 AM
Slow Model? – How to Increase Revit Performance |
Thu, May 23, 2013 at 2:22:22 PM
Revit 2013 slow performance in citrix |
Wed, Nov 5, 2014 at 11:03:13 AM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
