52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Plotting
Fri, Oct 17, 2008 at 9:01:12 AM | Plotting
jbohan
Revit Architecture 2009 We are having accuracy problems with plots. The paper size we are using-dsize is plotting about 10% too small. So the plots re not accurate. We are using an HP 1050. Also raster plots work sometimes but the title and border come out gray scale. We are using the same driver we use for AutoCAD.
Mon, Oct 20, 2008 at 10:23:02 AM | Plotting
KevinKernaghan
I guess the first place to start would be to make sure that "fit to page" is turned off in Print Setup.  "Zoom" should be selected at 100%.  Paper Placement should probably be centered, and you may have to check that there isn't some setting in the printer properties that is causing a weird zoom factor.
I've had title and border come out grayscale sometimes and I think it occurs when I leave a drawing on a sheet "activated." Be sure to deactivate all views when you're done editing sheets.
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:56 PM
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:05 PM
Plotting HELP!!
Tue, Nov 14, 2006 at 3:13:10 PM
Plotting
Fri, Apr 28, 2006 at 8:31:02 PM
plotting problem
Wed, Dec 22, 2004 at 3:44:51 PM
Page generation time: 6.8515
