39 Users Online (37 Members):
Forums >> Revit Building >> Technical Support >> curved concrete beam
8 Posts No Rating |
i've been trying to create a curved concrete beam all day but can't seem to get past the fact that i don't know how to create a concrete beam profile (which is not included in revit 2009 imperial library\profiles\structural), which then will i be able to use the profile in an in-place family. most curved beam discussions seem to revolve around w-flanges, not concrete rectangular beams. please help, a step-by-step would be most ideal as i am fairly new to this game. thanks in advance!
![4 Stars: 19 Votes](/images/stars_4.gif) |
If you only need one or two it would be easiest to create a component. Go to Structural, click component, create in place, and choose the structural framing catagory. Extrude your beam and give it a material type of concrete and under the physical tab assign concrete. Concrete parameters will be assigned. If you have loads of these and they need to be parametric then create a family using the structural framing - beam catagory.
8 Posts No Rating |
with a bit of trial and error and a lot of your guidance, i have managed to create the beam. thank you!
Parametric Curved Concrete Beams |
Wed, Dec 9, 2009 at 12:56:32 PM
Curved concrete beam |
Tue, Mar 20, 2012 at 1:27:05 PM
vertical curved beam |
Wed, Sep 5, 2012 at 10:55:57 AM
Tapered, Curved, Concrete Retaining Wall |
Mon, Jun 8, 2015 at 3:47:06 PM
Concrete Beam and Slab |
Mon, Jun 3, 2013 at 2:47:31 PM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
