40 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Deleting Door Instance Parameters
Thu, Oct 16, 2008 at 12:28:50 PM | Deleting Door Instance Parameters
Jmarchese
Is it possible to delete the "Frame Type" parameter out of the instance parameters list for a Door?  I'm working in Revit Architecture 2008.
Thanks,
Jim
Thu, Oct 16, 2008 at 4:52:06 PM | Deleting Door Instance Parameters
You can edit the family .... but why do you want to delete it?  You don't have to fill it in or use it.
Fri, Oct 17, 2008 at 8:01:53 AM | Deleting Door Instance Parameters
Jmarchese
I wanted to delete it because we are using a custom Frame Type shared parameter and I didn't want to confuse our end users.
Fri, Oct 17, 2008 at 8:58:06 AM | Deleting Door Instance Parameters
Jmarchese
Instance Parameters in titleblock not linking
Wed, Dec 28, 2011 at 10:31:23 AM
12
Door parameters not scheduling or tagging in double door.
Mon, Sep 26, 2011 at 3:29:50 PM
Door / Window Instance Properties....
Thu, Apr 1, 2010 at 5:26:16 AM
Add Yes/No Instance Parameters to Test
Mon, Aug 12, 2013 at 3:43:59 PM
type versus instance and fuzzy behaviour
Mon, Apr 18, 2005 at 9:46:56 AM
Page generation time: 0.9551
