38 Users Online (36 Members):
Forums >> General Discussion >> Revit Project Management >> Revision Clouds Turn off/ Tag to stay on
2 Posts No Rating |
If you have a revision cloud that has a TAG assoicated with the cloud, is there a way to turn off the cloud and leave the tag on? There is a manager in the visiblity graphics under the annotation categories, but whenI turn off the Revision cloud, the tag also turns off. Help Please.
2 Posts No Rating |
Never mind...i figured it out.
if you are going to take the time to post. why not post the answer so every one can benefit. that is the purpose of this site.
15 Posts No Rating |
The solution is to go to settings, revisions, this will bring up the setting for revisions and the way revisions are displayed in a drawing. From here you can tell it to show clouds and tags, or only clouds, or only tags per revisions. The only down side to this is say for example you have to revisions 1 and 2 on a sheet. Say you want to turn off the cloud for revision 1 but for revision 2 you want the cloud and tag to stay on. So you do the settings. Everything looks good on the first floor plan, but when you go up to the upper level revision 1 has the cloud turned off, but in reality you want the cloud and tag to show. Any ideas on how to get revisions clouds and deltas to show up per sheet? Thanks in advance
Revision Cloud |
Tue, Dec 14, 2010 at 1:03:05 PM
Revision clouds - off on one sheet but not on other sheets - is this possible? |
Fri, Mar 16, 2012 at 9:13:39 PM
Revision Cloud Goof! |
Fri, Jan 20, 2012 at 8:39:14 AM
Revision Clouds |
Tue, Dec 18, 2007 at 10:52:44 AM
Revision Clouds |
Thu, Sep 11, 2008 at 2:19:42 PM
Members: | 2056516 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
