Forums >> Revit Building >> Technical Support >> Creating Hills! Help Please
8 Posts No Rating |
Hi I just have a quick question How would you go about creating hills in revit? I want to make a slanted driveway, and make the land around it a hill. here is a very exagerated photo something like this with a driveway on it http://www.sacred-destinations.com/england/images/avebury/silbury-hill/silbury-hill-hdr-cc-tag.jpg of course it isnt going to be that steep, i only need it to go up about 6 feet if that if i posted this in the wrong section then somebody tell me and i'll repost it somewhere else or a moderator could move it please.
Hi Kevin Have you done the tutorials on topo surfaces, once you've done those you'll have no problems making a small hill. Just create a toposurface by points and incrementally change the elevation height, you can edit in 3d and elevation views aswell until you get what you are after.
55 Posts No Rating |
Yup, Teddy is right, you can read the tutorial about toposurface.. you can create contour using point or you can import dwg or csv file to Revit... and for driveway along the contour, you can create it with subregion... but, there's a good thread here about toposurface, but I forgot where it is... :D
Where do you live? |
Fri, Nov 20, 2009 at 1:02:29 AM
Revit 2015 Missing Toposurface Points? |
Sat, May 16, 2015 at 8:58:27 PM
creating vehicles |
Thu, Nov 16, 2006 at 12:18:26 PM
Creating a PLT file directly from Revit for sending to HP 750 plotter, how? |
Mon, Sep 24, 2007 at 10:22:46 AM
Creating window check reveals |
Fri, May 6, 2016 at 10:16:00 AM
Members: | 2115756 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
