80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2009 Rendering Accuracy
Wed, Oct 15, 2008 at 2:39:00 PM | Revit 2009 Rendering Accuracy
kevspicer
We are having great difficulty getting the colors in our finished exterior renderings to be even similar to our selected colors. All colors, whether from Revit, or custom RGB tones, render many times lighter than we expect. The ground and sky look normal, it's not as if the rendered images have an overall overexposure.  Even the shadow side of the building seems too light. On one example, we had to alter an accurate RGB color value acquired from Benjamin Moore down to 25% of its original luminosity in order to get rendering output that looked at all similar to the color chip.
What we would prefer to do is to be able to have the client select colors that we can download or scan, and then apply those RGB values or Jpeg tiles to the materials and have them render in a fairly representative way.
Our interior images end up a bit too light, but within acceptable tolerance and really do look so much better than the previous cartoonish system and we'd just like to get our exteriors looking as good.
Thanks for any help you can provide!
Wed, Oct 15, 2008 at 4:35:48 PM | Revit 2009 Rendering Accuracy
teddynugget
teddynugget Avatar
3 Stars: 2 Votes
We have the same issue.
To get the colours to look right we have to make the RGB values darker. Sometimes this means changing values between each render until it looks correct, which can be quite time consuming.
Is this what most people are having to do? Or is their something we are missing.
Like Kevspicer said, i don't think it is the expose settings we use as i've tried playing around with these a fair bit.
Any insights would be greatly appreciated.
Thanks
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
shared coordinate accuracy
Wed, Feb 6, 2013 at 8:50:17 AM
Rendering material accuracy
Tue, Oct 23, 2012 at 8:59:08 AM
Helping rendering in 2009
Sun, Apr 19, 2009 at 8:24:59 AM
Page generation time: 2.8681
