57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Wraps
Wed, Oct 15, 2008 at 12:04:40 PM | Wall Wraps
AmyCRErde
I need help manipulating wall wraps.  I'd like the exterior material (let's say brick) to wrap in and stop at the face of the exterior sheathing.  Instead, Revit wants to take it to the center of the wall structure and does not seem to give me any means to adjust that.  I have attached 3 jpeg immages.
1 is a cavity wall with no wraps (Revit)
2 is a cavity wall with exterior wraps(Revit)
3 is a cavity wall drawn in AutoCAD which looks exactly like what I want.
How can I get Revit to draw it correctly, like we always have in AutoCAD?
Wed, Oct 15, 2008 at 12:56:18 PM | Wall Wraps
4 Stars: 203 Votes
Something like this: see image attached
Wed, Oct 15, 2008 at 1:12:41 PM | Wall Wraps
AmyCRErde
Yes, but yours still cuts into the exterior sheathing a little bit.
How can you control that?
Wed, Oct 15, 2008 at 1:20:15 PM | Wall Wraps
4 Stars: 203 Votes
With the "CORE"... I hope this solve the problem...
Wed, Oct 15, 2008 at 1:44:46 PM | Wall Wraps
AmyCRErde
I tried your solution but found no real difference.  I can achieve the same thing by simply adding an inch to my air space.  It seems to want to return the brick exactly 2.666" regardless of how it is defined.  Try deleting an inch from your air space and see what result you get.
Also, once I get this one solved my next problem is to figure out how to adjust where the door and frame sit within the wall system.  The door frame needs to be framed within the stud wall width, not the veneer.  AutoDESK allows you to shift the location of the door within the wall system depth but I have not found that here yet.
Wed, Oct 15, 2008 at 2:15:51 PM | Wall Wraps
4 Stars: 203 Votes
Well i think it works fine, about the door you can control the frame position in the properties of the door in "FrameOffset-External" and you have the others parameters to control the rest of the door...
Edited on: Wed, Oct 15, 2008 at 2:16:30 PM
Wed, Oct 15, 2008 at 3:38:20 PM | Wall Wraps
AmyCRErde
I appreciate the hint on door placement, thanks.
If anyone else has any ideas for a more precise control of wall wraps, I'm still interested in hearing it.
Thu, Oct 16, 2008 at 3:08:20 AM | Wall Wraps
tim123
4 Stars: 19 Votes
Try adjusting the wrap layers and wall closure settings in the door construction parameters.
Thu, Oct 16, 2008 at 7:07:15 AM | Wall Wraps
AmyCRErde
Thanks Tim, I've tried that but it does not allow me to adjust the exact extent of the wrap in a cavity wall and it does not help me with wraps at an opening where there is something other than a door, like a curtain wall defined and a wall type or an intersecting with a different type of wall.
Thu, Oct 16, 2008 at 8:22:09 AM | Wall Wraps
tim123
4 Stars: 19 Votes
AmyCRErde
Try the attached PDF - the door has a closure ref plane it (although some don't, so you may have to edit the family).  The door can then overide the wall wrap settings.  The ends can be controlled using the wall wrap settings.  I don't seem to be able to get this to work with curtain walls though.  You may have to overide these with the 'Edit Cut Profile' function.  Hope this helps.
Thu, Oct 16, 2008 at 8:44:22 AM | Wall Wraps
tim123
4 Stars: 19 Votes
It does work with curtain walls inserted into an opening, but not with embedded curtain walls.
Thu, Oct 16, 2008 at 1:06:40 PM | Wall Wraps
AmyCRErde
Fri, Oct 17, 2008 at 12:37:05 PM | Wall Wraps
#13
coreed
coreed Avatar
4 Stars: 16 Votes
is this what you are looking to do
http://revitfamilies.blogspot.com/2008/03/wall-closure.html
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Oct 17, 2008 at 1:17:25 PM | Wall Wraps
#14
AmyCRErde
That looks like EXACTLY what I'm talking about Thanks!!  I can't wait to try it.
Wall wraps at inserts
Tue, Jun 28, 2016 at 3:50:38 PM
Door deletes when I edit wall type.
Mon, May 1, 2006 at 2:27:03 PM
wall wraps
Tue, Jan 31, 2006 at 4:47:15 AM
Wall wraps
Tue, Sep 25, 2007 at 11:29:19 AM
Wall join and wraps
Wed, Jan 22, 2014 at 7:24:53 AM
Page generation time: 0.7537
