56 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Scalloped Barge Boards
I attach a photo of what I am trying to achieve. My client want the barge boards of an extension to be scalloped. Perhaps not similair to the photo but same principal. I know that to get a fascia or barge board you go to Modelling, Host sweep and then roof fascia. But this gives a rectangular uniform shape. I have scratched my head till it hurts. Any idea anyone? regards Mark
The Trick is to make a Void family. See attached file. Create an In place family. It must be the same type as the part you want to cut. (roof) Draw Voids in the shape you want removed. Use the cut geometry tool to remove the Void from the part. Voids can be very hard to use. They are hard to select, hard to find, and don't always work. Ultimatly you might want to make a Generic Family Roof based that does the same thing. Up to you.. Enjoy...
----------------------------------- BallewDesigns.com |
Alternatively you could create the barge board by just extruding the outline shape and then applying a sweep to create the profiled edge. The finial could be created in the same in place family, as could the profiled cornice at the top of the barge board.
Mark - see the attached file
Thanks, I am playing around now. Thank you very much. I understand both thoughts. Mark
Scalloped Barge Boards |
Thu, Oct 23, 2008 at 11:48:37 AM
Skirting boards |
Tue, Dec 15, 2015 at 3:36:54 AM
Custom barge board/ fascia end profile |
Mon, Oct 15, 2012 at 3:14:42 PM
12
Applying skirting boards to walls |
Fri, May 20, 2011 at 7:18:42 AM
What is the best way to create corner boards? |
Fri, Apr 13, 2007 at 3:34:11 PM
Members: | 2057545 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
